Trac. cntrl light comes on, brakes don't work???
Old Aug 9, 2007 | 04:36 PM
KyleBlue85Iroc-Z's Avatar
When stopping the brakes work fine, all the way until the last few feet before coming to a complete stop. Then about the last couple mph the "traction control" light comes on and the brakes let up a bit. Almost like the ABS is trying to kick in. It doesn't seem to be a mechanical issue. Anyone know where to start??
Thanks!
Kyle
Old Aug 9, 2007 | 04:39 PM
mdacton's Avatar
I found a similar problem in a car......all of the sudden the pedal just dropped down
Old Aug 9, 2007 | 05:16 PM
96ZCamaro's Avatar
I had same problem on gravel roads. But I dont have my abs hooked up right at the moment and havent had the problem since.
Old Aug 9, 2007 | 05:20 PM
I've seen that happen due to problems with the rear sensor, on the differential housing. Pull it and check for a buildup of metal particles.
Is it the "traction control" light, or actually the "LOW TRAC" light?
Old Aug 9, 2007 | 09:39 PM
strbcks241's Avatar
Mine does this too! I've checked the sensors at both hubs...
Old Aug 9, 2007 | 09:40 PM
strbcks241's Avatar
On mine, the low trac light comes on and the pedal drops down for a second, then the ABS INOP light comes on and everything returns to normal.
Old Aug 9, 2007 | 10:44 PM
The low traction light comes on. No ABS light ever comes on. I'll go up and check the sensor sometime tonight.
The low traction light only comes on when it happens, then goes away once you're done stopping.
Old Nov 20, 2007 | 09:10 PM
xzodion's Avatar
Were havign the same proble, the trac light comes on and the brakes are almost completly faded out. Then the abs light comes on and stayes on and every thing is fine. The light will stay on till the engin is shut off again. And on start up it is hit and miss wither every thing is running fine. Brakes are probly a few months from needing changing front and rear and the fluid is good. When changed the rear abs harnest, and the rear wheel sensors. And the axle had to be changed last december. could this be a lose ground? Im gonna cheak the sensor at the diff as soon as i can. hopping this helps, and thanks for the ideas.
Old Nov 21, 2007 | 01:08 AM
Just FYI. My problem just went away. I'm thinking it was because the car had been sitting for a month or two and there was rust on the calipers. After about 20 miles it quit doing it. Now if it just hadn't blown the head gasket!!
Old Nov 21, 2007 | 11:09 PM
blwnlt4's Avatar
I had a similar issue with my brakes and traction control, after triple checking everything i found that the large wire loom (about 2'' diameter) that runs right next to the steering shaft had a hole rubbed through it and the insulation on the power wire for the abs control unit was grounding out onto the shaft.
Your problem might be totally different but it never hurts to look
Old Nov 23, 2007 | 04:09 PM
Severous01's Avatar
did it....worked for me.
but i dont have trac-con, so i dont know if yours is in the same place.
Collector Car
Jan 5, 2015 10:58 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
thenewkid
Nov 29, 2014 04:54 PM
