For those of you who changed your Torque Arm....
Old May 22, 2008 | 06:35 PM
Leader One's Avatar
were you able to do it while the car was on ramps and/or jack stands? Or did you have to have it on a list for clearance issues?
I'm getting a "thumping" right in the transmission tunnel area and I think it is caused from the Torque Arm and/or rubber bushing. I figure if I'm going to jack it up to see if the rubber is worn or if there is a problem with the Torque Arm I might as well change it out.
I welcome any and all feedback from anyone that has been in the same boat I am in.
Thanks in advance.
Old May 22, 2008 | 06:46 PM
slowride94z's Avatar
on the floor with jack stands f+r with the rear ones under the car not the rear end but jack under the rear cover to keep the rear from rotating up
changing it means not stock replacement right?
Old May 22, 2008 | 07:28 PM
Leader One's Avatar
Yep! Aftermarket. I was thinking a BMR unit. I was hoping to get away with a Non-Adjustable unit even though my car is lowered.
Any thoughts?
Old May 23, 2008 | 03:48 PM
if your going to buy any how spend a little more you wont regret it, look to the future for a plan
Old May 23, 2008 | 04:12 PM
slomarao's Avatar
get the adjustable one otherwise you ll kick youself later.
Old May 24, 2008 | 08:36 AM
Z-RATED94's Avatar
Not only get an adjustable one, get a chassis mounted TA. If your lowered, your pinion angle is most likely off.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BLK1997Z28
May 7, 2015 03:01 PM
KYWes
Apr 24, 2015 09:17 AM
