sway crazy
Old Sep 7, 2005 | 07:55 AM
s i c trans am's Avatar
sway crazy
hey i've noticed for a while now and its getting worse, but when im going at speeds higher than 60 mph when i change lines the whole car sways ridiculously. And even worse my wheel is very easily moved out of my control when passing each set of wheels over the lineto switch lanes. this problem is scary and causes my whole car to go side to side when passing over the line to switch lanes. Im definately putting my money on a suspension related problem. Does any one who is a guru at suspension know what exactly is causing my problem or does any one else share this problem. thanks for any input.
Old Sep 7, 2005 | 08:03 AM
sweet93z's Avatar
Re: sway crazy
id say you should stop trying to git ur dun and stop hitting fences and maybe it would be working right. Or maybe its because im better than you.
Old Sep 7, 2005 | 10:23 AM
OBE1 95Z28's Avatar
Re: sway crazy
The stock suspension wouldn't drive like that; jack the car up and look over the suspension components. Are all of your sway bar end links in place (several guys have had a missing end link).
Old Sep 7, 2005 | 12:38 PM
respectirocz's Avatar
Re: sway crazy
yea definatly sounds like a busted endlink
Old Sep 7, 2005 | 01:44 PM
Re: sway crazy
well i just replaced the rear end and the sway bar is that little one that curves around the cover and attaches under the quarter pannel and to the axles right? bec i tightened everything down pretty good. so now i have no idea? if the sway bar isnt perfectly lined up or tightended can it cause that? Also i might want to add i had drag radials on my car for like 3 months before hand, and one of my friends came up with a theory of my already old supension getting warped due to the extensive squats from the drag radials(i couldnt spin them). idk im totally confused, a little more help please!
Old Sep 7, 2005 | 04:42 PM
OBE1 95Z28's Avatar
Re: sway crazy
Again check your suspension components (torque arm mount, torque arm bolts to rear axle, end links, shocks leaking?).
RUENUF
Mar 13, 2016 03:37 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
