Sway Bars
Old May 8, 2005 | 10:05 PM
Chris_Camaro's Avatar
Sway Bars
Which type of sway bars should i order, hollow, or sollid, and wich company, PLEASE tell me ur experiences with your choice also
Old May 9, 2005 | 10:39 AM
Bayer-Z28's Avatar
Re: Sway Bars
BMR Is am\n awesome company that makes relaible parts..Eibach is good too... Not sure on the hollow/solid choices tho. I'm going to have to pay attention to this one, also..
Old May 9, 2005 | 01:52 PM
Z28barnett's Avatar
Re: Sway Bars
Hollow front, don't bother with solid, too much weight little stiffness increase.
Stock rear bar.
I would contact Sam Strano, and run his 35mm or 1LE 32mm.
1LE was $25.00 on ebay from gryhead.
z28
Old May 9, 2005 | 08:29 PM
Re: Sway Bars
whats "1 le"? and does eibach make a sportline spring kit for the V6, cus on there site says V8 ONLY, i want my car lower then the prokit.
Old May 9, 2005 | 11:21 PM
Red96Lt1's Avatar
Re: Sway Bars
1LE refers to GM's version of the Autocross. It was an option on some cars. As far as solid, little increase is not a true statement. Ask about the hollow. There has been a big debate on which one is better, a 35 hollow or a 32 solid. Given all things the same except dimensions, lets look at the engineering of them.
The equation for angular displacement rigidity is:
Theta = (T*L)/(G*J)
Theta - angular displacement
T - torque
L - Length of the bar
G - refers to the type of the material
J - Polar moment of inertia
For a cylinder J is as follows
J = (pi/32)*(OD^4 - ID^4)
So if everyting is the same but the dimensions then G, L, T, and theta are constant, so we can effectivley take them out of the equation. Basically what I'm trying to say a solid 32 bar is equal to a hollow 35 bar is the ID of that bar is 25.93 mm. So ask the company that makes the 35 what the ID is and then make your decision. Hope this clears some things up.
Edit for spelling errors.
Old May 9, 2005 | 11:54 PM
ayalam's Avatar
Re: Sway Bars
hey where did u get that equation sounds like something in my engineering physics book? just interested.
Old May 10, 2005 | 12:03 AM
Red96Lt1's Avatar
Re: Sway Bars
It's in my Engineering design book. If you want any more about it just hit me up.
Old May 10, 2005 | 01:42 PM
Z28barnett's Avatar
Re: Sway Bars
Theta = (T*L)/(G*J)
T - torque
FYI,
32mm 1LE bar is hollow not solid, the factory Z28 30mm bar is hollow not solid. Only the rear bars 19 & 21 mm are solid.
If I use your figure of 25.93 for the inside dia of a hollow 35mm bar.
The x-sec area of the bar is 748.2mm^2
A solid 32mm bar has a x-sec area of 962.12mm^2.
So a 35mm hollow bar with the same stiffness as a 32mm solid bar is 28.6% lighter.
I don't think that people want to hang anymore weight on the front of their cars.
I think the strano 35mm bar has a 6mm wall but I havent measured it myself, so it would be stiffer than the solid 32mm and still much lighter.
Z28
Old May 12, 2005 | 05:02 PM
Red96Lt1's Avatar
Re: Sway Bars
I was refering to my BMR solid 32 mm bar.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
force10
Jul 30, 2015 04:56 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
