Suspension Techniques 35mm or Sam Strano 35mm hollow ?
Old May 18, 2004 | 10:00 PM
ls1_bc's Avatar
I'm about to switch my front sway bar.Have any of you made the switch from the S/T 35mm to Sam's Hollow 35mm?Is the savings in weight worth the trade off in stiffness.I asume the hollow bar is not as stiff as the solid one.
Old May 19, 2004 | 09:13 AM
Camaro_Maniac63's Avatar
7/8ths the strength yet a lot lighter than the solid... I would definitely go with the hollow one.
Old May 19, 2004 | 11:31 AM
VegasZ's Avatar
I have the S/T 35mm front sway bar and it is hollow.
Old May 20, 2004 | 08:29 AM
Red96Lt1's Avatar
Hollow should suit you just fine. The OD is the biggest contributing factor to the torsional stiffness. It has a bigger moment arm against torque because it's bigger. The inside contributes little to the torsional stiffness. Wow, I guess those engineering classes are paying off.
Old May 20, 2004 | 09:38 PM
Bud M's Avatar
I would go with the hollow bar too.
Old May 22, 2004 | 08:50 PM
tanmanski's Avatar
Assuming price is not a factor for ya, Strano is highly regarded...however for me, budget is everything, I went with the ST 35 & like it very much. Yes it weighs more (10# maybe?) than the hollow bar, but for me the price offsets the weight penalty, especially if you do some other weight reduction or relocation mods anyway. I got the ST front & rear set for $260 I believe it was, free shipping.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
Slayer
Aug 17, 2015 03:55 PM
force10
Jul 30, 2015 04:56 PM
