Suspension Question: Road quality vs Performance
Old Sep 3, 2007 | 01:01 PM
NiteRider's Avatar
A question for you suspenson guru's. Currently I have the Eibach Sport-Line springs on my 00 SS, shocks/strutz are some unknown name or stockers I guess. My question is what would the ride quality be with Bilstein SLP's revalved shocks, not HD ones. I'm more concerned about keeping the car a tad bit comfortable rather than taking corners ar high speeds. What do you guys recommend, changing the springs are out of the question, the car sits exactly as I want it to.
Old Sep 3, 2007 | 04:42 PM
Greed4Speed's Avatar
The problem I've heard people complain about sportlines is that there is too little spring rate for the rear allowing the frame to contact/ride the bumpstops. No shock will fix this.
Old Sep 3, 2007 | 08:04 PM
NiteRider's Avatar
That's what I feel, sometimes over a big bump, BAM! Thing is I had a setup in my 94 Trans Am, Bilstein HD's and the sportline, never felt the same kind of bang as I do now. It just feels like there is dampening going on. So again I ask if the SLP Bilsteins will just work out better than the HD's on lowering springs. Did search and I got alot of mixed results.
Old Sep 4, 2007 | 10:45 AM
Bud M's Avatar
Sam Strano can probably spec Bilsteins for you with spring rates better suited to those springs than the SLPs.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
Collector Car
Jan 5, 2015 10:58 AM
