suspension help please
Old May 30, 2005 | 01:18 PM
squeelyblue99's Avatar
Hey guys,
I've been a memeber for a long time but i'm usually just a lurker. Anyway, I have a 97 Z with 135,000 miles on it. I notice it rides pretty bad compared to my 99 v6 camaro-when I take a turn fast I hear a squeel from the back and it also just seems harder to keep on the road I'm planning on buying slp take off shocks and struts but I'm also looking at 1LE rear springs and a 32mm front sway bar. Compared to the rest of the car I know very little about suspension so: will that combo fix the problems I'm having? Am I just wasting my money buying the springs and the sway bar? Are there additional parts I should be buying? I just want the suspention to be at stock specs or a little better--I just got married and don't have the money to do anything fancy. Any advice would be appreciated.
Thanks!
Old May 30, 2005 | 10:44 PM
Z28barnett's Avatar
Re: suspension help please
Originally Posted by squeelyblue99
Hey guys,
Thanks!
Buy the way you do not have struts, you have coil over shocks.
Front sway bar is a good idea. The rear springs are not a good idea unless you get the matching fronts 360 in/lb and they are hard to find.
The stiffest end slides first, so stiffer rear springs will just make the car more tail happy.
Due to the work involved don't buy SLP take off's get some good shocks and you won't be doing the job again right away.
If you want ride quality don't mess with the springs and be careful what you buy in the way of shocks.
Your tires are not listed, they have more effect than any other part on the car when cornering.
Sam Strano gives good advice and sells some good stuff.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
