Suspension Advice (~$750)
I recently swapped out my shorty headers/stock y-pipe for a Pacesetter LT’s and a 3” ORY. Now my ground clearance is pretty much non existent. I figured it would be so that’s fine.
My suspension modifications can be found on my fQuick (link in sig) but basically… sportlines in the front, stock slp level 2 in the rear, and stock bilstein shocks, lower control arms, relocation brackets, adj. panhard bar.
Here’s what I’m looking for.
Car is a ’97 SS M6 with the optional bilstein level II suspension and ~ 152,000 miles on the odometer.
Thanks!
- The car should handle good. The car will be a cruiser, but I’d like to road race it or auto-x it. It will see the drag strip, some, but traction should be considered 2nd to handling.
- Ride height should be around stock SS height (-.75”) to pro kit/strano height (-1.25”)
- Cost is an issue, I’d like shocks/springs for sub $750 if possible.
- Adjustable shocks would be a plus, I’d love koni 4/3’s and strano springs but I think it may be out of my price range. Can I build a pretty adequate suspension cheaper?
Thanks!
Current ground clearance
I'm kind of leaning towards getting a set of stock SS springs. Would I be better off getting the bilstein through them, a set of revalved bilstein's from sam strano, KYB AGX Adjustable Gas Shocks (adjustable dampening on car) or am I regret getting anything less than Koni 4/3's?
depends which ones you get. If you get the 12 ways they have adjustable rebound, etc. Also look into tokico shocks.
Thanks!
Thanks!
I have the Strano/Koni setup w/Sam's Swaybars and love it, but if your looking to stick within your budget and get all new parts maybe a set of Strano's with new Bilstiens would be best. JMO
Do you still have the original 1LE front springs ? If so just swap them back on with a new set of Koni's and I think you would be happy. Although the shocks alone will eat up your $750 budget.
the SLP Level II springs are not the same as 1LE springs.
I see, Interesting as I was unaware of the differences in Level II springs, If the're the same ones used on the later `98 -up Bilstein equipped SS's then aren't they Eibachs ?
Either way you need a stiffer rate for the front, I still vote for Strano's.
I looked forever to find something that would work for me, and Strano's name kept popping up. I was determined to find something on my own, but he seemed to be the best source of information. He is a VERY busy guy, but he will help you out. I didn't want to spend the money, and I knew that Koni's were the best option. After speaking with him on this, I bit the bullet and went with the Konis (the fronts have the adjustable spring perch too for approx. 3/4" of drop). They are still on sale, and you can get the 4/3 set for $750 and free shipping. When I ordered mine, the rears were on back order and he was getting short on the fronts.
If I were you, I'd save the hassle, and do what everyone else winds up doing and go with the Konis. At $100 off the normal price and free shipping, you can't go wrong!
Henson071
Dec 30, 2015 09:55 PM
