Suggestions on TA
Old Oct 24, 2004 | 08:37 PM
97 Z-28's Avatar
Suggestions on TA
Hey all, I am tring to figure out what TA to go with. My issue is I have LTs with Duel Exhaust (X-Pipe). I was wanting to get the BMR Trak-Pak, but I don't think it will fit with my x-pipe. So I think my only option is the BMR Trans mount TA. Is there anything I might be missing, or is that my only option?? Thanks
Brad
Old Oct 24, 2004 | 11:34 PM
WiseguyZ28's Avatar
Re: Suggestions on TA
Go for a Spohn Torque Arm, Speed Inc is havin a group purchase on them right now, look in the GroupPurchase vendor sales on this site. I'm gettin one from it.
Old Oct 25, 2004 | 10:23 AM
Roadie's Avatar
Even the Spohn won't clear the x-pipe in the standard "X behind the transmission" fashion. I'm in the same boat and thinking about getting the Spohn torque arm for long tubes (big opening where the Y-pipe converges) and re-creating the duals.
Here's my plan... Put the X where the Y converges (between the Spohn mount and undercarriage). Replace the upper panhard rod mount with the BMR one that gives extra-clearance for exhaust. Then run both pipes down the passenger side and out the back of the car.
This way, I get the beefy torque arm, the true duals with X-pipe, and I get to send them out the back of the car and use a set of corsa tips I have sitting on the shelf.
Old Oct 25, 2004 | 08:07 PM
Bud M's Avatar
There are other trans mount torque arms but the BMR is probably about as good as any of them. Spohn makes a trans mount TA too.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
