Which Subframe connectors
Old Sep 30, 2009 | 08:44 PM
kamon8404's Avatar
Well I'm in the market for some subframe connectors, bolt on would be my preference. However, the subframe toward the front of car is pretty banged up. I'm guessing its from the previous owner using them to jack up the car. Does anyone know of any subframe connectors that bolt elsewhere? I have seen some weld on ones that weld to the frame before that subframe. I would just prefer to not have to find a welder around town to do it.
Old Oct 1, 2009 | 07:39 AM
97FormulaWS-6's Avatar
Bolt in subframes are junk; just get the weld in ones from BMR or UMI. They'll do a lot better job, and having them installed shouldn't be that hard to find someone to do it.
You don't need a welder; just a collision shop or performance shop.
Old Oct 1, 2009 | 09:50 AM
kamon8404's Avatar
I was thinking of getting the spohn racing ones. Anyone have any feed back on those?
Old Oct 1, 2009 | 10:06 AM
Spohn makes a good product as well.
Old Oct 1, 2009 | 03:55 PM
Bud M's Avatar
I'm happy with the quality of my Spohn Torque arm, I'd look at the SFCs if you had provided a link.
Any muffler shop should have a welder capable of installing SFCs.
Old Oct 8, 2009 | 12:12 PM
blue 79 Z/28's Avatar
UMI 3 points are the best non custom SFC's ive seen
Old Oct 8, 2009 | 12:52 PM
kamon8404's Avatar
Yeah i'm going to go with spohn weld on connectors, and UMI trailing arm relocating brackets.
Old Oct 16, 2009 | 11:23 AM
bluz28's Avatar
I've got Spohn 2 point weld on connectors, great quality but any of the UMI or BMR weld on would also work great!
Old Oct 18, 2009 | 08:14 AM
SMO Q's Avatar
I had a good amount of power being made before I put on my sub frames. The body was twisted, so I had to force the sub frames in place using a floor jack. I went with the BMR weld in sub frames, and the body is much stiffer, I notice it alot when the car hits second gear. The body used to twist but its straight now.
Old Oct 18, 2009 | 04:09 PM
RUDEDOG's Avatar
BMR 3 point bolted and welded.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
