Subframe Connectors
Old Feb 12, 2006 | 09:16 PM
91 Camaro RS's Avatar
Subframe Connectors
I'm looking at getting these for my car, but I need to know how hard they are to install and where exactly they install. Thanks.
Old Feb 12, 2006 | 09:34 PM
00cls1camaross's Avatar
Re: Subframe Connectors
i knwo when ibought my bmr sfcs they came with a little direction paper
Old Feb 12, 2006 | 09:48 PM
I figured they will, I'm asking because I want to know if I can install them myself in my driveway or if I'm going to have to take it to a shop and have to pay to get them installed.
Old Feb 12, 2006 | 10:52 PM
n2ceptor's Avatar
I had a muffler shop weld them in..... Just get references, so you know it will be done right..
Old Feb 12, 2006 | 11:01 PM
fasteddie94's Avatar
Depends on what you got. They almost always mount to the front control arm mount. SLP's bolt under the tailshaft crossmember and then again in the front subframe. Summit sells another set that you bolt to the control arm mount, then the floor pan and then to the subframe. Yes you could do it in your driveway with a jack and jackstands, but you should have them welded. The bolt holes may slot out letting them move and defeat the purpose all together.
So you have two options.
Buy the bolt in ones and pay a muffler shop to weld them up, possibly save a little money.
Buy the weld in ones and pay someone, unless you have access to a welder.
I'm going the bolt on route so you have a double attachment at any one point. Something to think about.
Edit: I was assuming fourth gen until I paid attention to the screen name. Should be the same principal though.
Old Feb 12, 2006 | 11:23 PM
My dad knows how to weld, but he has a very large construction welder (it's for welding together steel casing), I don't know if that would be too much for this little job or not, I'd have to ask him.
Old Feb 13, 2006 | 05:36 PM
I'm sure you could crank down the heat and make it work. Should be a dial or crank on it somewhere. Try it on a similar thickness scrap piece first and you'll be good to go.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
