subframe connector testimonials
Old Jan 28, 2007 | 01:10 PM
ajlew9428's Avatar
anyone that has subframe connectors. did your frame feel stiffer? less noise, flex? tell me what the car felt like after. Also, where can I get bolt in SFC s
Old Jan 28, 2007 | 01:33 PM
2000GTP's Avatar
SFCs are one of my favorite chassis/suspension mods and made one of the more noticable differences on the car. The car feels alot tighter and any road noise it used to make is now completely gone. Definitely one of the better upgrades I have done. Umiperformance sells bolt-in style SFCs.
Old Jan 28, 2007 | 04:10 PM
RE AND CHERYL's Avatar
It made the car feel 5 years newer. 2/3 of the squeaks and rattles were gone. Definately a must have mod.
Re'
Old Jan 28, 2007 | 08:05 PM
ajlew9428's Avatar
WOW! Sounds like This is my new priority.thanks
Old Jan 28, 2007 | 08:14 PM
ajlew9428's Avatar
anyone know where the cheapest place to get umi bolt in sub frame connectors is? Also is the 3 point worth the $100 over the 2 point umi connectors?
Old Jan 28, 2007 | 08:53 PM
JakeRobb's Avatar
Super Moderator
A lot of people will tell you that bolt-in SFCs won't show as much of an improvement as weld-in, especially over time. Just FYI. Others will tell you that bolt-ins are fine.
Personally, I'll be going with weld-ins.
Old Jan 29, 2007 | 09:25 AM
ajlew9428's Avatar
The only reason Im going bolt in, is b/c I heard I would have to pull carpet for weld in. Did anyone not have to pull the carpets, or any interior?
Old Jan 29, 2007 | 09:28 AM
davidz28guy's Avatar
carpet shouldnt be an issue with the weldins, there underneath your car
Old Jan 29, 2007 | 01:43 PM
ajlew9428's Avatar
So I shouldnt have to pull anything out of the interior at all?
Old Jan 29, 2007 | 02:38 PM
JakeRobb's Avatar
Super Moderator
Some people weld the SFCs to the floor pan as well as to the subframes. This makes them even stronger. Since a good weld connecting the SFCs to the floorpan will penetrate to the other side, there is risk of setting the carpet on fire.
I've heard of very experienced welders successfully welding SFCs to the floorpan without removing the carpet, but I wouldn't try it myself.
Old Jan 29, 2007 | 03:12 PM
2000GTP's Avatar
Are you planning on welding these in yourself? You shouldn't have to remove any carpeting to do the job. The main thing to be careful of when welding is to keep clear of the fuel lines.
Old Jan 29, 2007 | 04:52 PM
ajlew9428's Avatar
ya. Im a body man, so Im quite experienced in welding. When we did sub conects on a fox, we had to remove the carpets. I guess they have different mounting points
Old Jan 29, 2007 | 07:23 PM
myslowcamaro's Avatar
ive had sfc's for 2 years now, unfortunately, its been sitting in its original box in my garage for 2 years need to get them welded on.
Old Jan 29, 2007 | 08:06 PM
NOSCaMaRo's Avatar
Slightly stiffer ride but not harsh, I think they were a good investment.
Old Jan 30, 2007 | 10:51 AM
LiENUS's Avatar
You could get bolt-ons and then weld them on, use the bolts to hold em in place as you weld...
