sub frame
Old Sep 25, 2005 | 06:17 AM
dragster98's Avatar
sub frame
are 4th generation camaros sub frames removable? the frame horns ar bent can i just swap with another frame or is it all part of the body? pics would be great if any one has any the reason im asking is i might buy this camaro but the horns ar bent 90 degrees to the left its a fully loaded 98 z28 needs a front clip and only has 57,000 on the clock should i press on for a diferent car? they want a grand for the car http://i18.photobucket.com/albums/b1...en/camaro2.jpg http://i18.photobucket.com/albums/b1...n/P2010073.jpg http://i18.photobucket.com/albums/b1...n/P2010074.jpg
Old Sep 25, 2005 | 10:13 AM
ishz28's Avatar
Re: sub frame
Unless there aftermarket, 4th Gens. don't have sub-frame connectors, it's a uni-body design. What do you mean by frame horns, where on the car?
Old Sep 25, 2005 | 10:35 PM
97BBlackZ's Avatar
Re: sub frame
Ouch. How much are they asking in the 1st place? I'm sure you would have to cut that out and reweld a whole new one in. but maybe someone else can chime in
Old Sep 25, 2005 | 10:52 PM
69gto96z's Avatar
Re: sub frame
I bought a 96 Z with less damage in the front than that one. I just parted it out, it wasn't worth the trouble to me. Once they are hit there, and esp that bad, they are F-ed up, look to see if it bent the floor pan underneath. I paid $1500 for mine with everything there, and all new panels. I say that is a rip for a grand. I definately would not buy it.
Old Sep 25, 2005 | 11:00 PM
dragster98's Avatar
Re: sub frame
thanks for your input i did find complete cars undamaged on the net for about 1500 or less i need a solid rolling chassis to make into a drag car guess ill keep looking
Old Sep 25, 2005 | 11:31 PM
69gto96z's Avatar
Re: sub frame
I have the one I bought. It is fixable but wasn't worth it to me. It is practically stripped though. Good luck finding one.
Old Sep 26, 2005 | 12:26 AM
dragster98's Avatar
Re: sub frame
i just need a rolling chassis dont care if it has motor or tranny dont care if the seats and carpet are gone i do need a clean body and all lights
Old Sep 26, 2005 | 11:19 PM
I burn rice too's Avatar
Re: sub frame
If your talking about the rails, then yes, you can repair those. You have to section in the rails with a new part. You can get them from G.M.. Call around, different dealers, different prices. The rest of the car can be pulled back together on a frame rack. This is where you need to find a competant body shop that has the time to do this. Look for certification from, ICAR, Masters, and good ol' ASE. ICAR is the most obvious sign of a good shop.
Since this isn't going to be a show car, then I wouldn't worry about the way it looks, just make sure that the frame measures out. Ask for the print out!! All of the numbers should be in the green. They will also have to make some rough pulls before they splice in the ends. Any more questions feel free to pm me. I might know a guy or two that could help you out. and remember, if this was 1998 and the car only had 10,000 miles on it it more than likely would have been repaired.
One more thing, try the tow yards, I sold a 98' Z28 minus engine and tranny hit less than that for $300 to a salvage yard. Salvage yards sell parts, tow yards just want to get rid of the junk!
Old Sep 27, 2005 | 05:01 PM
dragster98's Avatar
Re: sub frame
great thanks
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
Aug 5, 2015 08:35 AM
