"strut" brace install
Old Sep 17, 2005 | 06:05 PM
robertotrevino's Avatar
Ok, so I got a new strut brace... how in the heck do I take the screws off? I tried everything, I even broke the wrench, I tried for 2 hours and all I got was a bruised forearm and a cut hand... niether of the 4 nuts would move not even a 1/32ths of an inch. How do you do it?
Old Sep 17, 2005 | 06:22 PM
Re: "strut" brace install
I don't know what to tell you besides "good tools and strong arms"...and maybe some penetrating oil . I don't remember them being that much trouble.
Old Sep 18, 2005 | 12:42 AM
I tried oiling them but no give... It's weird cuz I had never seen a craftsman tool break.
Old Sep 18, 2005 | 01:27 AM
AW/whiteZ-28's Avatar
I have...Many times... Mostly my fault though...
I would say spray it really good with penetrating oil let it sit over night then try it the next day. If not use a impact on it.
Old Sep 18, 2005 | 03:24 AM
Getsome17's Avatar
switch the wrench from tighten to loosen
Old Sep 18, 2005 | 09:34 AM
jfischer's Avatar
I put a BMR STB on my 2002 Z28, and the nuts came right off with no problems. They're not even on all that tight.
Are you sure you're turning them counter-clockwise?
Old Sep 18, 2005 | 11:21 AM
2000GTP's Avatar
I dont see how you could possibly be having problems like that. Try some PB Blaster and let it soak for a day or two, it has worked miracles for me.
Old Sep 18, 2005 | 11:29 AM
MRBoss429x's Avatar
Mine came off very easily. Make sure you're going the right way. If you are and still have trouble try soaking them in PB Blaster over night.
Old Sep 18, 2005 | 11:33 AM
barbs97z's Avatar
worse comes to worse...take it to a local mechanic and have him use and impact gun...
Old Sep 18, 2005 | 11:54 AM
yeah, I let it soak over night, gonna try and take them off today, if not, I'll take it to a mechanic, thnx.
Old Sep 18, 2005 | 01:23 PM
Lower's Avatar
When you go to reinstall the bolts after getting the brace on, you may want to keep in mind that they shouldn't be torqued on that hard. 37 ft/lbs -which isn't much!
Old Sep 18, 2005 | 02:22 PM
Slayer63b's Avatar
I don't know my rk sport stb has been a hassle for me too. I did'nt put it on tight and it made some weird sounds up front. I tightend it more and it still sound funny just not as bad. but I did progresive rate springs and billstein hd shocks at the same time. Still wonder what could it be?
Old Sep 19, 2005 | 12:10 PM
I tried the air gun, now I basically have a round nut that wont budge...I tried everything, what now? I'm afraid to use the impact gun cuz that may damage the bolt and I'd have to replace the whole shock base.
Old Sep 19, 2005 | 03:06 PM
Z95m6's Avatar
Are you going the right direction? Counter clockwise loosens.
Old Sep 19, 2005 | 07:58 PM
Greed4Speed's Avatar
A ratcheting box end wrench did it for me.
