Stock sway bars with Upgrade?
Old Feb 11, 2007 | 07:44 PM
mook99TA's Avatar
Any just upgraded to poly endlinks and bushings while using their stock sway bars. Does it offer any improvement or do I really need to chage everything. Don't want to spend the money on sway bars if I can fix my body roll with some bushings and end links. Anyone that has done this let me know how it worked.
Old Feb 11, 2007 | 09:55 PM
OBE1 95Z28's Avatar
Poly bushings for the end links will help a bit, especially if the stock bushings were worn. Not going to give you the improvement that larger sway bars do. I'm running Strano's 35mm hollow bar up front with the 1LE 21mm solid rear bar. Strano sells a hollow 22mm rear bar.
If you decide to upgrade to Stano's bars, they come with poly bushings and new end links.
Old Feb 12, 2007 | 11:55 AM
Bud M's Avatar
I wouldn't expect much difference from replacing bushings only. Another vote for Strano's bars.
Old Feb 12, 2007 | 12:06 PM
Sam Strano's Avatar
Bushings don't make the bars any stiffer, they only make the bars react a touch more quickly *IF* the stock bushings are shot. If not, because the stock endlink bushings are a very hard material you're just tossing some money away.
Old Feb 13, 2007 | 02:46 PM
GreenDemon's Avatar
Used 1LE swaybars are pretty cheap if you can't spend a lot of money. That way you're not wasting money on poly bushings for a stock swaybar.
Old Feb 13, 2007 | 02:51 PM
Sam Strano's Avatar
Any SS, WS6 or Firehawk has the "1LE" front bar already, and while it's better than a stock 30, it still ain't enough front bar. And a "1LE" rear bar is a 21mm, and really 90% or more of the 1LE's had a 19mm bar (all '94-99's from GM), only '93 GM built 1LE's were a 21 rear. And frankly a 21 rear with a 32 front is only workable if you have what the '93 1LE's did... a stiffer front spring with a stock rear. If you put a 32/21 combo on a stock sprung car, it's too stiff in the back. And I feel a 32/21 is too rear stiff relative to the front anyway.
Old Feb 16, 2007 | 10:17 AM
mook99TA's Avatar
Sam what do you suggest for bars on a stock sprung car because I don't want to change my ride height?
Old Feb 16, 2007 | 10:51 AM
Sam Strano's Avatar
Height doesn't matter so much, it's the spring rates.... I use the same size bars in either case. Big front, moderate rear. That's 35/22 hollow from me
Old Feb 16, 2007 | 11:58 AM
mook99TA's Avatar
how strong are your hollow vs. solid bars?
Old Feb 16, 2007 | 12:09 PM
Sam Strano's Avatar
Basically just about the same, but much lighter. Bars work by twisting, and the very middle of a bar/tube moves very little, the further you get from the middle the more movement which is why bar stiffness is a function of the outside diameter to the 4th power. Basically on the front you are dealing with a hollow 35, but we use a think 1/4" wall tubing for extra strength, on the rear we use a thinner tubing and the 22mm rear bar is equivilent to a 21 solid.
BTW, all front bars on 4th gens...... Hollow.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
