squeak from rear axle
Old Jan 26, 2007 | 12:47 PM
eliterider06's Avatar
I have a squeak coming from the rear axle that for the life of me I can't find. I've heard that in 95 which is the year of my car the z28's rear axles had some kind of trouble with this. Has anyone heard of this and if so what I need to do to fix it. Thanks for the help
Old Jan 26, 2007 | 08:01 PM
KillerTA's Avatar
I think you need to lubricate the bussings.
Old Jan 26, 2007 | 08:02 PM
RE AND CHERYL's Avatar
My rear had an annoying squeak. Turned out a LCA bolt was a little loose and was causing it.
Re'
Old Feb 6, 2007 | 11:27 PM
bobyoblava's Avatar
i had a rear axle bearing issue that was making that kind of a noise
Old Feb 7, 2007 | 12:45 AM
Westlotorn's Avatar
We had the same issue with 97 Z28, turned out to be the rubber gromet where the shock bolts to the body. Had to pull carpet in back to access but it was an easy fix with new shocks. The rubber gromet separates the upper shock mount bolt from the body, ours was split allowing the metal bolt to rub on the body with every movement of the car. Squeak about drove us crazy before finding it.
Old Feb 9, 2007 | 07:42 PM
DrivingZiggy's Avatar
When my '95 had a squeak, well maybe a groan, coming from the back, it turned out to be the suspension hanger.
Old Feb 9, 2007 | 08:22 PM
apss's Avatar
check the sway bar bushings. very very common on f- body's.if so replace w/polyurathane. run ya 'bout $20
PROJECT X
Apr 17, 2015 12:13 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Jan 3, 2015 07:22 PM
rockync7
Jan 1, 2015 05:10 AM
