SLP SFC with Spohn Body Torque Arm
Is this do-able? from what i understand about the 2 parts, is that the SLP bolt on SFC, bolts to the tunnel brace support and the spohn T/A w/body mount, mounts there also? i may be wrong abotu the T/A. but does this sound right? will the SFC's get in the way of the torque arm?
Re: SLP SFC with Spohn Body Torque Arm
if the SFC's bolt too the tunnel brace mounts, yes they will be in the way
why not just get a set of tubular SFC's?
the triangulated SFC's seem too be a PITA when it comes too adding aftermarket parts and the difference between the 2 different styles is going too be negligible IMO
Originally Posted by CreatiVe2
do you have a link to the global west?
ok, i see how with studs they could work... ARP? and what size... because when i get the SFC's in im goign to want to go LCA and TA right away... thx for help
Originally Posted by john35thss
Have both on my car and my brother in law's car, works great and bolts up fine just need to use studs instead of bolts.
John
John
UMI Performance recommended the 3-Point SFC's to me when purchasing the tunnel mounted torque arm. The SFC's take the stress instead of the floor board, its a pretty sick set-up. Check out the picture below, give UMI a call and I am sure they can set you up with a price on both
http://www.umiperformance.com/images/2004b.jpg
I have slp triangulated sub frame connectors, and the spohn torque arm. I put the torque arm over the sub frames. Works great. I just bought longer bolts. No studs needed. I have yet to run into any problems doing it this way. Go for it, it stiffens that bizzich right up! I love it!
