Shock replacement question!
Old May 15, 2006 | 05:40 PM
97BBlackZ's Avatar
Alright so my rear passenger side shock went out and now when i go over bumps it the fender lip cuts into the the tire .
So im looking to replace them. I check just now and they have gabriel Pro Ryder Premium Gas Shocks.
I did a search on google and couldnt find these damn things.
Does anyone know of a place that sells them and also how good are these shocks? They were on the car when i got it.
And is it ok if i get a different brand? I think the fronts are the same. I don't know if you can mix and match them..
Old May 15, 2006 | 07:27 PM
tfs95z28's Avatar
Re: Shock replacement question!
you can mix and match... shouldnt make a difference.
Old May 15, 2006 | 07:35 PM
Camaro_Maniac63's Avatar
Mixing and matching may not be a great idea; different shocks have different damping and the shock(s) with of course different damping will act differently, which might cause the car to be unbalanced. And those Gabriel shocks are very poor; if you can afford to pay around $300, go for Bilstein HDs if you are sticking with your stock springs.
Old May 16, 2006 | 06:59 PM
97BBlackZ's Avatar
Alright well im about to replace the shocks and i was reading the write up from someone else and it said to remove the wheels.
Now cant you replace them without removing the wheels??
Because i lost my lock key and i really dont want to have to bust these things off..
Old May 16, 2006 | 07:38 PM
Steve0's Avatar
You can do the rears without removing the wheels... but not the fronts.
Old May 16, 2006 | 09:10 PM
97BBlackZ's Avatar
Aight thanks. Just got done. But i don't think it solved my problem
sscott
Jan 17, 2015 04:30 PM
Hurin
Dec 13, 2014 07:38 PM
pologreen97z
Dec 2, 2014 10:42 AM
Brad 97z
Aug 10, 2002 09:58 AM
guionM
14
Jun 19, 2002 08:30 AM
