which SFC would you get for a DD?
Old 08-22-2007, 10:50 AM
ssvegas's Avatar
i know this has all been beat to death, but between these TWO which would you get for a daily driver and WHY?
http://www.spohn.net/product.cfm?productid=1394
or
http://www.umiperformance.com/2003?category_id=129
THANKS for your input.
ssvegas is offline
Old 08-22-2007, 11:50 AM
Greed4Speed's Avatar
Spohn, because all that extra bracing isn't needed.
Greed4Speed is offline
Old 08-22-2007, 12:20 PM
Z-RATED94's Avatar
Really? I wish I would have asked before installing the KBDD subframe and the Spohn chassis mounted TA that connects to it, which Steve thought was the way to go.
Z-RATED94 is offline
Old 08-22-2007, 01:25 PM
ssvegas's Avatar
Zrated, are you saying the spohns TA is worthless or the KBDD SFCs are no good?
what are KBDD SFCs?
ssvegas is offline
Old 08-22-2007, 04:27 PM
ABA383's Avatar
I think the Spohn one's will be fine...I have a set of Hotchkis on mine since 1995 and they are similar in design...There's a custom shop around here that makes their own out of CM and they are the best I've ever seen for fit, finish, etc and they are the 2 point style...Guys in the 8s and 9s use them so I guess they are working...
--Alan
ABA383 is offline
Old 08-22-2007, 09:25 PM
Z-RATED94's Avatar
what are KBDD SFCs?
Both are excellent pieces. The Kenny Brown Double Diamond sub-frame connecter might be overkill, but I wouldn't change a thing. The Spohn front mount of the TA ties into it, to make one very solid set-up. Steve at Spohn, said this was a fine way to connect the TA. Rick
Old 08-23-2007, 12:15 AM
Bud M's Avatar
I'd go with boxed BMRs, they make a good place to put a jackstand
But between those 2, probably the Spohns. I dont think the extra bracing on the UMIs is all that valuable unless you have a tunnel mount torque arm.
Bud M is offline
Old 08-23-2007, 02:59 AM
karpetcm5's Avatar
I have the spohns works perfect for me plenty of ground clearance even with a 2 inch drop immediatly noticed a nice difference especially getting in and out of driveways and ofcourse cornering as well. Car feels way more solid, well worth the mod for me.
karpetcm5 is offline
Old 08-23-2007, 06:58 AM
ssvegas's Avatar
thanks for the input fellas. think i'll just get the spohns. im getting spohn LCAs and SA panhard installed next week!
ssvegas is offline
Old 08-23-2007, 08:20 AM
Z-RATED94's Avatar
Pay the little extra and get the adjustable panhard rod. That way you can keep the rear of the car centered over the rearend. This is a must have for using drop springs or even if the stock ones start to sag a little.
Old 08-23-2007, 10:26 AM
ssvegas's Avatar
i am...single adjsutable (SA)...sorry i thought thats what that meant...?
ssvegas is offline
Old 08-23-2007, 10:44 AM
Its a daily driver, not a drag car.
Who ever Steve is. Talk to Sam Strano and see what his opinions on SFC's are in general. Even if dragging is your thing, there are plenty of 11 and 10 sec cars not running a DD set up w/out issues so why add the weight?
Old 08-23-2007, 10:54 AM
ssvegas's Avatar
yea im not adding them for cornering...i've talked to sam.
but i do want to tighten things up.
ssvegas is offline
Old 08-23-2007, 04:12 PM
Z-RATED94's Avatar
Your right. What was I thinking? All that weight from the extra support is useless. And yeah, who's Steve anyways.
Old 08-23-2007, 05:59 PM
ABA383's Avatar
Steve is Steve Spohn...He may know a few things about drag racing...who knows?
--Alan
ABA383 is offline
Quick Reply: which SFC would you get for a DD?
