SFC are clunking...
Old Jan 14, 2006 | 01:55 PM
96DubyaS-6's Avatar
SFC are clunking...
Just had SFC's installed a few weeks ago. I now have a very noticeable clunking noise coming just from the rear. Seems that it only happens when the rear tires go over a large bump. Front chassis is completely unaffected. They are UMI tubular weld in. Just curious if anyone has had this problem, or if it is an install mistake.
Old Jan 14, 2006 | 02:36 PM
NOSCaMaRo's Avatar
Re: SFC are clunking...
tighten the rear of the control arm mount up to 90 ft lbs. Since the SFC mounts around the control arm mount it doesnt allow the bushing to compress, that should fix it.
Old Jan 14, 2006 | 09:35 PM
OBE1 95Z28's Avatar
I think he meant to say tighten the front bolt of the LCA; many SFC's mate with the front bolt.
Old Jan 15, 2006 | 04:27 PM
NOSCaMaRo's Avatar
Yes sorry this is what I meant, tighten the bolt where the SFC goes around the front control arm mount.
ImNraged
Aug 19, 2018 08:02 PM
HarleyZ28
Oct 5, 2015 06:23 AM
87Aerocoupe
Jan 10, 2015 07:27 PM
rje
Sep 9, 2002 12:35 PM
