Rounded Head on Flare Fitting
Old Jun 23, 2009 | 05:59 PM
METALBEAST's Avatar
I was installing my new line lock for my 97 Z28. I used a 12 mm flare wrench to try to take off the front brake line from the master cylinder to the ABS. Well needless to say, I rounded off not one but BOTH of the damned fittings. I am at a loss. How can I get these bastards loose?
Old Jun 23, 2009 | 06:53 PM
https://www.camaroz28.com/forums/sho...d.php?t=600213
Look at posts 15 and 17.
Old Jun 23, 2009 | 07:36 PM
METALBEAST's Avatar
Originally Posted by shoebox
Is there anything you HAVEN'T done on an LT1 lol!
Thanks as always shoe! I'll give it a try!
Old Jun 23, 2009 | 11:30 PM
I am sure there is more to explore. I haven't done that much to mine as compared to a lot of people.
Old Jun 24, 2009 | 07:56 AM
JohnD's Avatar
I devised a method some years ago to deal with flare fittings. End wrenches don't usually cut it and flare wrenches aren't that much better. I took a box end and a cutting wheel and cut a big enough hole in the box that I could get the wrench over the line and then put a big pair of vice grips around the box to hold the thing together while I cussed, levered, beat on, wrenched it off. It worked and didn't hurt the nut either. Some heat really helps there as well. Check out the layout of the parts for best angle before you decide where to do the cut on the wrench.
Old Jun 24, 2009 | 10:54 AM
There's always more than one way to skin a cat. A vice-grips over a regular flare nut wrench might work, too.
Old Jun 24, 2009 | 11:28 AM
JohnD's Avatar
Absolutely. I have done it with a flare nut wrench too. There are times when the 6 side wrench is better and sometime the 12 is better depending on the circumstances.
Old Jun 25, 2009 | 08:14 AM
METALBEAST's Avatar
Update.
I managed to get them off using a combination of a couple of things.
First, I soaked the nuts with what little Sea Foam Deep Creep overnight.
I went to Sears on my lunch break & purchased a set of metric Craftsman Extreme Grip wrenches. They are basically designed to grab the sides of fasteners that have been rounded off on the edges.
I also purchased a new LockJaw pair of locking pliers & a new can of PB Blaster.
When I got home from work, I sprayed the two nuts with PB blaster & let them set for about 30 minutes. I then started with the nut on the ABS unit first since it was the easiest to access. I used the 12 mm Extreme Grip wrench. With little effort, the flare nut broke loose & I was able to get it off. Nexted I tried the same method with the flare nut on the master cylinder. This was much more difficult due to the fact that the line to the rear brakes was very close to the flare nut I wanted to loosen. The Extreme Grip wrenches have to go on a very specific way or they will not work. I could only get part of the wrench on the edge of the nut. When I tried to break the nut loose, it just rounded off the very edge of the nut. Nexted I tried the LockJaw pliers. I set the clamping pressure to as high as I could close. I locked the pliers onto the nut & gave it a turn. With a little effort the nut broke loose & I got the line off. I installed the new line lock & solenoid shortly thereafter. Only thing left is wiring it up. Hope this writeup helps anyone who experiences this problem in the future. Thanks for all your help folks
Chris Anderson
Jan 27, 2015 08:30 AM
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
1 BAD BIRD
Aug 2, 2002 12:57 PM
