Replacing rear spring isolators with hose
Old Jun 22, 2010 | 02:52 PM
OBE1 95Z28's Avatar
I know this mod has been around for a long time to drop the rear height. Wondering if anyone has suffered damage to the body as the isolator distributes the load; in other words can the spring covered with hose dig into the sheet metal over time? Thanks.
Old Jun 22, 2010 | 05:38 PM
NJ-LE's Avatar
OBE1 95Z28:
I haven't had any problems though I've only done about 15,000 miles since the change. I think I wiped a little synthetic chassis lube on the top of the hose (lots on the inside!) but I'm not sure.
Old Jun 22, 2010 | 06:41 PM
OBE1 95Z28's Avatar
Thanks NJ-LE. What's the purpose of the lube? I assume the hose is to eliminate metal on metal contact to prevent scraping and rattles.
Old Jun 23, 2010 | 05:12 AM
NJ-LE's Avatar
OBE1 95Z28
Use heater hose that's a tight fit and the inside the hose lube is needed to slide the hose on the spring coil. I think I used a little on top to protect against the hose from abrading and possibly wearing though.
Old Jun 23, 2010 | 09:57 AM
Sleepy_Z's Avatar
what about cutting or shaving portions off the isolator?
Old Jun 23, 2010 | 01:16 PM
NJ-LE's Avatar
Sleepy_Z:
I've been trying to keep any stock pieces I remove from the car as is. I suppose you might be able to use a surface grinder to "shave" the stock isolator evenly but I think it would be quicker and easier to slide hose over the last coil of the spring and try them out to find out if you like it. Easy to go back if it doesn't work.
Old Jun 23, 2010 | 02:55 PM
OBE1 95Z28's Avatar
The isolator isn't very tall so cutting would most likely cause it to fail; probably will only drop the height 1/2" max. I'm running Spohn's lowering springs but my 9" Moser differential has larger axle tubes than the stock axle causing the rear wheel gap to be taller than the front wheel gap.
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
wytblur
Mar 2, 2003 03:40 PM
