Removing brake hoses from the hard lines
Old Jul 15, 2006 | 12:14 AM
nfa's Avatar
nfa
I posted a question about this earlier, and was told that flare nut wrenches and pb blaster should be used. I have been giving the nut on the end of the hard line a squirt of pb blaster over the past day or so. I put on the flare wrench and gave it a try, but it didnt work. I may have given up too quickly b/c b/c Im paranoid about rounding the nut. Would heat be beneficial to break the rust free? If so, should I be using a mapp torch or is propane fine? (I will be replacing the rubber hoses with stainless).
Mike.
Old Jul 15, 2006 | 03:02 PM
Re: Removing brake hoses from the hard lines
Often, flared fittings loosen best when "cracked" open. That means you securely put your flare nut wrench on it and give it a sharp pop to break it free. A lot of times it works better than steady, increasing pressure. Then, of course, there are those fittings that just won't come off without being destroyed.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
