Rear Suspension Questions
Old May 15, 2008 | 10:53 AM
96 Chamelon TTops Stock's Avatar
Here are the details:
'96 Camaro 3.8l TTops
196,556 Miles
I replaced the rear shocks last fall. The car has tons of body roll while cornering. It also bottoms out on small bumps. I have done nothing else to the rear suspension. I am a DYI kind of guy. I do not have much experience with suspension. If someone can tell me what is needed, or at least what to look for/ measure, I would appreciate it. I am on a limited budget, so expensive performance parts are out of the question. This is my daily driver, so I just need a reliable/ comfortable ride. My front and rear Drivers tires are wearing bald on the outer edges. I need to get new tires soon, but need to fix the suspension first, then tires & alignment.
The best place to purchase the parts would also help. If I can get a whole energy suspension bushing kit somewhere, that would be wonderful.
Thanks in advance for your assistance..........
Old Jun 4, 2008 | 10:39 AM
1lowZ-28's Avatar
body roll
i would check all the bushings. start with the sway bar bushings and work your way out. you said the tires are bad.. are they leaking air? if so, a low tire pressure will make body roll more prominent. jegs, summit and even orileys car poly urethane bushings individual or in a kit.
Old Jun 4, 2008 | 10:46 AM
97FormulaWS-6's Avatar
Basically replace all the suspension bushings, either with stock pieces (rubber) or aftermarket (poly); then get the alignment and such. Should run ~$150-$200 for all the bushings; and a long afternoon to replace all them.
Old Jun 8, 2008 | 03:58 AM
dregsz's Avatar
In my opinion, (as an experienced race driver), and others may argue the point, but body roll is a fuction of spring rates and sway bars, (AKA anti roll bars) while poly bushings may help, a Z28 front bar may help, but in terms of bang for the buck, I would get a set of eibach prokit springs. Summit sells a house brand that they claim to be the equivelent for $169. (check to make sure they fit on V6 spring perches)
That wold flatten it out quite a bit.
Check tire pressure. outer and inner wear combined would indicate low pressure.
only worn outers on the front would indicate negative camber which is good for handling. I don't know how you can get only outer wear on the rears, (check to see if it is insides also.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Hurin
Dec 13, 2014 07:38 PM
94z28jbw
Sep 8, 2002 03:22 PM
