Rear Spring Rubber Isolators, Help?
I have a 1995 Z28 that I bought new. Years ago the rear axle was changed under warrranty due to excessive noise from the limited slip.
I am planning a suspension upgrade, I was checking out the rear springs and noticed that the spring has no rubber isolator on the upper or lower rear spring perch.
I am concerned that the mechanics might have left them out and thrown them away after changing the axle.
Does anyone know if the rubber isolator was factory installed on 1995 Z28's????
Thanks for reading my post
Thanks for the replys
I guess it is a profit issue, Dealerships must pay the mechanics about $10.00 an hour and charge GM or you $70.00.
I get so weary of having to check the work of everyone that touches my car. I never thought that anyone would leave out a pair of 5"dia rubber doughnuts and send a car out the door.
The lack of this isolator may explain why the rear bump stops were destroyed. Only the bolts and shreds of the rubber stop's where left. The loss of 1/2" or so, of ride height might have put more load on the stops. I have been driving the car like this for at least 8 years.
The rubber hose sounds like a good idea, or I will try to find the P/N of the isolators.
If anyone else can confirm that 95 Z28 had the isolators I would like to hear about it.
Rubber Isolator P/N:10290379
The P/N: of the isolator if anyone needs it.
10290379
GMPD-GM LIST: $16.16
OUR PRICE: $9.21
I guess I will buy two, to correct the oversight of the mechanics, at least they remembered the springs.
10290379
OUR PRICE: $9.21
Re: Thanks for the replys
I have a 97 ss that I bought new and no one has ever done any rear end work and Mine doesn't have them. I also get the clanking noise form there when going over bumps as a result. I'm sure you guys have heard of many people that have that noise.
Re: Rear Spring Rubber Isolators, Help?
I remember seeing a reply from Sam Strano in ls1tech.com regarding the heater hose mod. I think he said that using rear springs, without any form of spring isolators, will cause metal to metal contact and that, eventually, the springs will form a hole in the car's body. And that's why, at the minimum, people would use a 5/8"-3/4" heater hose in place of the much thicker rear spring isolators to lower the car 1/2"-3/4".
Dec 1, 2014 08:08 AM
