Rear end cover install?
Old May 13, 2004 | 08:41 PM
remaxracer45's Avatar
What are you guys using for a gasket on the rear end covers on your camaros? I bought one of thos finned aluminum ones and it looked like it was rtved on before? also what about rear end oil and additives?
Old May 13, 2004 | 09:10 PM
Xride's Avatar
wrong forum for this but...
use whatever gasket you want, dont use RVT, doest stick to oil.
use umm cant remember what its called, but its black goo.
use a gasket, (most covers come with one) just get a GM one if you need to.
for fluid, 70W90 and GM limited slip aditive
use whatever brand oil you want really, I used royal purple, but only becuase it doesnt cost any more then the generic stuff for me.
Old May 14, 2004 | 11:10 AM
thermwood1's Avatar
I typically use a stock paper gasket and i also use the copper seal sealant. Never had a problem with leakage. Using the 2 together makes it easier to take off later. Just a suggestion.
Old May 15, 2004 | 12:35 PM
Bud M's Avatar
My manual says to use a gasket and RTV on the cover side of the gasket. That has worked for me.
Old May 15, 2004 | 12:44 PM
Xride's Avatar
I should add that while you have it off you should put the hardered maincam studs in.
take them out one at a time.
Old May 15, 2004 | 10:17 PM
xcam not sure what you are talking about? what studs and where do they go? what is the benefit to changing them? where do I get them?
Old May 16, 2004 | 02:26 AM
Xride's Avatar
ARP studs, the benifit, they are stronger then the stock ones, and with the 10 bolt that can only help.
they are about 30 bucks I think.. if that.
they are bearing main cap studs.
they should help esspecially if your new cover has the preload studs (I really hope it does)
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
