rear end
Old Aug 8, 2006 | 12:47 PM
gpss97's Avatar
rear end
ok don't really know anything about rear ends, but my car and my buddies 2001 z28, the rear sits about 1/2 inch out on the passenger side. someone told me that its possible that my car was wrecked, but found out my buddies 10k mile 2001 garage kept car is the same way. so i am just a lil curious as to what it could possibly be.. and another question i'm looking to get a 12 bolt or a 9", when a ten bolt goes out on you, what is it that actually breaks? or does it vary?
Old Aug 8, 2006 | 01:35 PM
MyShibbyZ28's Avatar
Re: rear end
Are the cars lowered at all? They might need an adjustable panhard rod to center the axle under the car.
When ten bolts break it is usually the teeth on the ring and pinion. The posi units seem to stay in tact for the most part, or slowly die off. Ring and pinions, though, snap.
Old Aug 8, 2006 | 02:50 PM
gpss97's Avatar
Re: rear end
my buddies car isn't lowered at all, it is sitting the way came from the factory, and mine just has all the hotchkis stuff on it, that i came with so i don't think mine has been lowered, unless slp did it i have no idea.
Old Aug 10, 2006 | 02:17 AM
hissin'98's Avatar
Re: rear end
mine was the same way, I just threw an adj PHR under and solved it
Old Aug 10, 2006 | 10:10 AM
Greed4Speed's Avatar
Re: rear end
SEARCH!!!!
This was discussed just last week.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
