Rear brake pads only contacting 1/2 the rotor
New brakes all the way around on the car, new calipers on the rear with new pads and rotors. The pads are only using 1/2 of the rotor, anyone know whats up? The outermost 1/2. The part of the rotor closest to the hub the pad is not touching. Wrong pads?
David
David
What brand rotors and calipers did you get?
If it's the wrong pads...should not have fit correctly in the calipers. I'm thinking wrong rotors maybe? I would be good to know what brand and p/n you installed.
David
I took the ABS off the car and just plumbed the lines together, I had read a bunch of opinions as to whether or not the car needs a proportioning valve or not. I elected not to.
Thanks guys
David
So how much vacuum do you have? And as far as the proportioning valve, there fairly cheap, why not throw one in to fine tune the front to the back? Do the brakes get any better once they have a little heat in them?
Sounds like the rotors have spread so the pad faces are not parallel with the rotor faces. It will wear in in time like shoebox said. I suspect its caused by driving with the parking brake on, heating the calipers enough to deform them.
David
07-04-2005 05:00 PM
