Rear brake caliper mount part number needed
Old Aug 16, 2004 | 07:19 PM
ltlhomer's Avatar
I sold my stock rear and forgot to pull the axles and get the caliper mounting brackets off of it so I now need the part number so I can order some new ones and throw in the 'ol 12 bolt.
TIA,
Sean
Old Aug 16, 2004 | 08:19 PM
Re: Rear brake caliper mount part number needed
Bracket part numbers.
Old Aug 16, 2004 | 08:36 PM
ltlhomer's Avatar
You're the man shoebox...but I'm sure you already knew that.
Old Aug 16, 2004 | 08:45 PM
ltlhomer's Avatar
The shim p/n 26034667 is not showing up on gmpartsdirect. The plates are right but I'm sure I'll need that shim too. Any ideas?
Old Aug 16, 2004 | 08:52 PM
Don't know. The p/n used to be good. I'd call Dal or Jason and ask about it. If you get any new info, let me know and I will update my mine.
Old Aug 16, 2004 | 09:00 PM
ltlhomer's Avatar
Okay I'll give em a call tomorrow and get back.
Thanks man,
Sean
Old Aug 16, 2004 | 10:02 PM
Dave89IROC's Avatar
are those for the OE 94 rear disk brakes?
if yes, classic industries sells them for $47.95 each
RH w/TC is PN G4645
LH w/TC is PN G4646
RH w/o TC , PN G4647
LH w/o TC , PN G4648
Old Aug 16, 2004 | 10:38 PM
RH w/TC is PN G4645
LH w/TC is PN G4646
That's the same as dealer list price. They are only ~$27 dealer wholesale. 1994s don't have TC, so don't have to worry about those pieces.
Old Aug 17, 2004 | 03:24 PM
ltlhomer's Avatar
Old p/n for shim was 26034667. New one is 12471185. The left and right backing plates were correct.
Thanks again,
Sean
Old Aug 17, 2004 | 03:44 PM
I'll update my stuff. Thx.
Old May 13, 2009 | 05:22 PM
lovmotors's Avatar
Hi,my friend in russia is bulding a camaro
here is a vin#2G1FP22S4S2148498
he need some parts for this car. thise are absolite from gm dealer
12471185
18021200
18019858
18019857
is any one can help e out with this problemm?
thanks
Old May 13, 2009 | 05:53 PM
ltlhomer's Avatar
12471185
18021200
18019858
18019857
thanks
I'll send a note to one of my GM buddies (worked there for two years) and see if they can cross-reference those to the new numbers for you. Email me at LTLHOMER@aol.com to remind me.
Old May 13, 2009 | 10:43 PM
12471185
18021200
18019858
18019857
thanks
All those parts show up at http://www.newgmparts.com . Might not be the cheapest source, but...
Old Mar 2, 2021 | 10:19 AM
callawaykj77's Avatar
Shoebox-I have looked through this thread about brake bracket axle shims and cannot find any place that sells the GM or classic industries parts that are mentioned. Do you have any insights/connections on where this part (12471185) can be found to buy. I need one asap. Thanks
Old Mar 2, 2021 | 05:59 PM
DrewHMS97SS's Avatar
https://www.hawksmotorsports.com/199...-10-bolt-pair/
Is this the same item you are looking for? Pricey, but nice.
