Question about LCA Brackets for Moser 9"
Do the bmr weld on lca brackets fit the moser 9" rear or do I have to get the ones from spohn. Please help asap, I need to get my wheel hop problem solved.
Steve
Steve
Re: Question about LCA Brackets for Moser 9"
I can't speak for BMR, but the Spohn stuff works and is top quality. I'm assuming you meant the relocation brackets for the control arms..Just a side note...If you are still running the stock TA with your 9" you will have massive wheel hop because the 9" center section is located slightly to the driver's side and will put the TA in a bind as it will be not located correctly. This is why the Spohn TA, and others have two sets of mounting holes in the differential end of the TA mount. I saw in your sig that your BMR Track pac was not installed yet...That may cure the problem of wheel hop.
If this isn't the case with your set up, then ignore the above and get the Spohn brackets
--Alan
...--Alan
lbrowne
Nov 13, 2011 04:25 PM
