Protane Bushings K Member
Old Dec 2, 2011 | 01:56 PM
aaron_depue's Avatar
How much would a mechanic shop charge to swap out the OE worn out bushings for the polyurethane bushings (kit)? I bought a prothane upper and lower A - Arm bushing kit.
I have the K-member out of the car and stripped down. I was thinking I might load it up and take it the the shop and have them swap out the bushings. Would they LIKELY charge an arm and a leg even tho i have already bought the parts and grease? I
Any estimates? Man hours?
Old Dec 2, 2011 | 05:46 PM
JohnD's Avatar
Re: Protane Bushings K Member
When I had the bushings replaced last year at a machine shop, they charged me $50 to do both arms, both sides and $30 more to r&r the press-n ball joints.
Old Dec 3, 2011 | 09:10 AM
Did you have the K Member out of the car? Sounds pretty reasonable
Old Dec 3, 2011 | 12:12 PM
JohnD's Avatar
No, the K member has never been out of the car. You don't need to do that to take the "A" arms off.
Old Dec 7, 2011 | 12:51 PM
UMI Performance's Avatar
Former Vendor
John D's pricing sounds pretty good.
Are you planning to have them assemble the lowers back on to the k-member? I'd wait and put them on at home...
It is pretty nice to have that out and clean it.
Probably one man hour with the right tools.
Ramey
UMI Performance
Old Dec 7, 2011 | 05:36 PM
yep. It was nice to pressure wash 150k miles and 15 years worth of funk of that thing.
Im guessing the lowers are pretty easy? I just need the shop to do the pressing since i dont have a press or impact gun for that matter...everything else i can do
Old Dec 8, 2011 | 07:49 AM
Former Vendor
Hey aaron.
Once the bushings are in, it's up to you to complete the install into the k-member. A few tips: Take a flat file or similar tool and make sure there are no sharp edges on the pickup points (where the a-arms bolt in) on the k-member. With fresh new bushings sometimes those edges can catch and slice into the bushing, which makes it harder to put it. Also, if you got a little packet of lube with them, use it about 2/3 on the wide side of the bushing and 1/3 on the narrow side. Lube helps a lot.
Don't worry if they seem difficult to put in. They fit pretty tight on purpose.
Ramey
UMI Performance
Old Dec 9, 2011 | 05:46 PM
Awsome. Thanks for the tip. i am replacing the upper and lower ball joints as well
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
