power slot rotors
Old Aug 13, 2007 | 08:19 PM
99-huggerZ28's Avatar
power slot rotors
my 99 z has 49,000 on stock rotors and pads... i want an upgrade over stock brakes without spending alot of money. i was thinking pro stop rotors with hawk pads. what do you guys suggest? where is the best place to buy powerslot rotors?
Old Aug 14, 2007 | 06:37 PM
Greed4Speed's Avatar
Stock replacement rotors that are heavier (stock is ~16lbs for the fronts. Most replacements are 18lbs up. Brands like Wagner, Brembo, Bendix are all better than stock), some better pads like Hawk HPS or Axxis Metal Master, and some fresh and more performance oriented brake fluid like ATE Superblue.
Old Aug 14, 2007 | 08:30 PM
Capn Pete's Avatar
I have the Powerslot rotors on my car, and so far they've been working great . I believe I bought/installed them at the start of '06, with a set of Hawk HPS pads. I took the car out on a couple track days, and the brakes seemed to work fairly well (a little bit of fading, but who knows if that was the pads and/or the fluid? ). BUT, what I DIDN'T like were the Hawk pads . While they did a great job of stopping the car (which obviously, is important) they dusted and squealed really bad. I hated that. This year I switched and started running ceramic pads. They're not any particular name brand (I think they're called "Satisfied" brakes? ) but I believe they're manufactured by a company like Wagner or Bendix . I've taken the car out a few more times to the track with these pads (and the Powerslot rotors) and the stopping power has still been very good (for street pads), they don't squeal, and they only dust moderately after running the track ... hardly at all just street running .
Hope that helps you out! FWIW, I believe Hawk makes ceramic pads for our cars too.
Old Aug 14, 2007 | 08:43 PM
"BUT, what I DIDN'T like were the Hawk pads . While they did a great job of stopping the car (which obviously, is important) they dusted and squealed really bad. I hated that. "
do the hawk pads dust more than stock pads under normal to moderate street driving? my c6 wheels stay clean with the stock pads. also did your hawk pads always squeal? or only after they were abused for awhile?
Old Aug 14, 2007 | 09:21 PM
karpetcm5's Avatar
I had hawks pads on my 93 Z, mine never made any noise but alot of dust.
Old Aug 14, 2007 | 10:43 PM
Rashiki's Avatar
I just put a 4 wheel disc SSBC kit on my car, and they seem to work pretty well. The rotors are slotted, and under fairly heavy braking from highway speeds they give a slight vibration, i'm assuming from the slots. Under normal braking they do not vibrate. I've noticed less dust than with my previous VGX pads, and the feel is the same. They were cake to install and I'd get another set. The rear drivers side pads took a bit to wear in (not leaving an even swept path) but now they're great. The only thing I don't like is that they rusted up on the non-swept area. I wasn't expecting them to look new forever though :P The kit was 280 or so. I'm happy
Old Aug 15, 2007 | 05:55 PM
Ceramic pads are harder and will wear your rotors quicker. I'm running the Axxis pads on my daily driver with open wheels and they dust is minimal. These and the HPS are the same pads that Sam Strano says he runs. I really like mine.
I wouldn't just go with some part store pads though. I had Wagner Thermoquiets and they sucked. They were quiet, and no dust, but they faded when pushed even slightly. Get some performance pads unless you don't mind less braking performance.
May 1, 2015 01:14 PM
QuickSilver02
Apr 7, 2015 11:12 AM
shroyvin56
Apr 3, 2015 08:15 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
