Poly tranny mount and torque bushing
Old Apr 30, 2007 | 09:23 PM
green96ta's Avatar
how much do you think that you would gain in a 1/4 mile from putting both of these on a car thats got 100,000. my tranny mount broke the other day so im guessin i was losin a lot latley to that worn out mount.
Old Apr 30, 2007 | 09:26 PM
mdacton's Avatar
its not going to make it any faster.....you do need to fix it tho
Old May 1, 2007 | 02:15 PM
matLT1's Avatar
I'm pretty sure you will gain 20rwhp from a new set of mounts.....
Old May 1, 2007 | 02:48 PM
nicks2ndZ's Avatar
im pretty sure he knew he wasn't going to gain power....if you were having traction problems because the pinion angle was incorrect from the torque arm bushing it could get you better traction improving 60' and et
Old May 1, 2007 | 03:11 PM
ABA383's Avatar
If you're going to keep the stock TA, then its a good mod...I was in the high 1.6s-low1.70s to 60' using the poly mounts...
--Alan
Old May 1, 2007 | 07:57 PM
Z28luvr's Avatar
will poly TA mounts work with a car that has RLBs?
Jason Short
Jan 19, 2015 06:34 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
