poly bushings in stock LCA's - now seem too sloppy
Old May 28, 2006 | 05:21 PM
maddog05's Avatar
I replaced the rubber bushings in my stock Rear 1995 Z28 trailing arms with poly about 5 years ago and the car handled like a new Z06 for a year or more now it is back to it's old self. Should I check the mouting brackets to see if they have flexed themselves into metal fatigue or buy Spawn LCA's with poly bushings in them. Something has weakened over time and it seems unlikely it was the poly bushings. Anyone experienced this? http://web.camaross.com/forums/image...s/confused.gif
Maddog
Old May 31, 2006 | 08:58 PM
supercharged94Z28's Avatar
Re: poly bushings in stock LCA's - now seem too sloppy
Well, I don't know too much about poly bushings, but I just got some lca's today with poly bushings and it says to only use some kinda silicon based synthetic water-proof grease.. Maybe if you used petroleum based grease, it wore them down faster.
Old Jun 1, 2006 | 07:53 AM
Dave K's Avatar
It's been said before and you can find a fair amount of information by doing some searching... but basically poly is not a good bushing material... it deforms and holds that deformation. My guess would be that if you pull you're lca's you'll find that there's a whole lot of slop in the bushings.
If you want compliant but firm handling AND durability... go with a harder durometer rubber. If you want handling with handling AND handling (and are willing to sacrifice all else at the altar of Handling)... then go rod end. Avoid poly unless you're comfortable replacing your bushings regularly. The poly bushings in my swaybars lasted about 20,000 miles... I just replaced them with new ones but next time I'm putting in a solid endlink.
canbaufo
May 25, 2015 12:01 PM
canbaufo
May 5, 2015 03:43 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
Jason Short
Jan 19, 2015 06:34 PM
Skull Leader
Aug 10, 2002 11:01 AM
