Pictures of my LS1 brake upgrade
Old Oct 5, 2004 | 03:27 PM
rlax31's Avatar
Here are the pictures I took during/after my install.
Here's what went on the car:
LS1 knuckles
LS1 Calipers painted red with CAMARO decals from Brent
Powerslot Rotors
Hawk Pads
Earls Lines (front and back)
Also pictured are the trans am panels I put on the same weekend
http://www.radford.edu/~rvandenhe/Pictures/Brakes/
The brakes not only perform great but they look sharp, very happy with the results
Old Oct 5, 2004 | 09:29 PM
Z95m6's Avatar
Re: Pictures of my LS1 brake upgrade
Looks good. I'm glad you're happy. How much did the T/A door panels set you back? I've been thinking about doing this.
Old Oct 5, 2004 | 09:49 PM
rlax31's Avatar
Got them in a trade for the used LS1 rotors I got in my setup and my stock hurst shifter.
Old Oct 6, 2004 | 09:03 AM
Red96Lt1's Avatar
Looks great. Did you powder coat the caliper or just paint it? If you powdercoated it, how much was it?
Old Oct 6, 2004 | 11:04 AM
rlax31's Avatar
Painted them. Cleaned them really well, 3 coats of Dupli-Color Red, then put the decals on, then 3 coats of Dupli-Color Clear
Old Oct 6, 2004 | 11:53 AM
Red96Lt1's Avatar
Awesome. Good job.
Old Oct 6, 2004 | 06:00 PM
buckethead's Avatar
which earls brake line kit did you use. I'm doing the front only on my 96. I called summit thay said the earls brake line kit for a 2000 camaro comes with 4 brake lines. I need 5, my car has 2 rubber lines in the front and 3 rubber lines in the rear.
Old Oct 6, 2004 | 06:09 PM
rlax31's Avatar
I used the LS1 stlye. They come with 5 lines actually. 2 front, 2 rear and one rear middle. The fronts and backs went on fine, but the 5th one was not the right size. I just kept the stock 5th one.
Old Oct 7, 2004 | 08:16 AM
LT4ever's Avatar
LS1 knuckles
Powerslot Rotors
Hawk Pads
I just got done doing the LS1 brake upgrade as well and found that I had to relocate the hard brake line mounting braket. It the stock LT1 location it stretched the flexible lines and then when the wheel was turned in the other direction the flex line would rub against the tire. I had to bend the **** out of the hard line to find the "sweet spot".. which for me was located in the center of the wheel.
Did you have to relocate the hard brake line mounting bracket? Or did the new Earl's brake line kit have longer hoses than stock LS1's?
Old Oct 7, 2004 | 08:17 AM
rlax31's Avatar
I didn't find any problem with the earl's LS1 lines, they seemed to fit fine. I however never compared the length of the stock LS1 lines and the earl's side-by-side
Old Oct 7, 2004 | 08:48 AM
LT4ever's Avatar
So did you have to move the mounting location and/ or bend the hard lines?
Old Oct 7, 2004 | 08:49 AM
rlax31's Avatar
Nope
Old Oct 7, 2004 | 08:51 AM
LT4ever's Avatar
The brake lines that came with the set up had a hard metal line that came out of the banjo bolt where it meets the caliper and then turns into a rubber hose. It has about 2" of metal line from the caliper. I'm wondering if this is a brake line out of a car with traction control or are all the LS1 stock flex lines like that?
Old Oct 7, 2004 | 08:59 AM
LT4ever's Avatar
Hmmm... just called a Chevy dealer and the brake lines are the same P/N for 98-02 cars w/ traction control and w/o traction control. So I now believe the brake lines that I have are used on stock LS1 f-bodys. Not that is does me any good, cuz I still have to custom fabricate my mounting bracket.
What a pain in the a**!!
Old Oct 7, 2004 | 09:01 AM
rlax31's Avatar
Yeah the old LS1 lines did have some metal right out of the banjo bolt i think.
