Passanger Side Subframe And Exhaust
Old Mar 18, 2005 | 07:39 AM
85irocrebuildtpi's Avatar
Hi Guys
I Have My Passenger Side Subframe Rail Hitting My Exhaust. I Have Cut Away Some Of The Subframe.
I Have The Single Cat Exhaust
Any Ideas On How I Can Get Past This?
Old Mar 18, 2005 | 01:39 PM
blackztpi's Avatar
Re: Passanger Side Subframe And Exhaust
so you cut part of the subframe connector, or the subframe itself? you definately didn't want to do that. most of the time you just have to pry at your exhaust without breaking anything.
Old Mar 19, 2005 | 06:43 AM
Frank89IROC's Avatar
On 3rd gen cars, many manufacturers of sub-frame connectors expect you to re-route your exhaust so that the connector on the passenger side will fit. I experienced this with the Hotchkis connectors. Spohn makes one that will fit without any modification to the exhaust. http://www.spohn.net/product.cfm?productid=1309
Old Mar 20, 2005 | 06:52 AM
no i cut some of my subframe connector but clearance is real tight.
i am going to try and heat the exhaust before and after where hitting and than put cold rag on it and see if it will pull away due to contration.
it would of been nice to know that i should of rerouted my exhaust....i had to weld my slp headers to my cat and thus this problem.....
rap rap rap with my nice rebuilt 350 and 305 heads reseated......i am a mild hot rod setup...
HOFFICER
Apr 6, 2020 10:36 AM
RUENUF
Mar 13, 2016 03:39 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Chris Anderson
Jan 27, 2015 08:30 AM
