oversteer/understeer
Old Feb 27, 2007 | 04:23 PM
maro z28's Avatar
Can someone please explain oversteer/understeer to me.
Thank...don't have time to do a search.
Old Feb 27, 2007 | 05:58 PM
Bud M's Avatar
Understeer is when the front of the car hits the wall, oversteer is when the rear hits
Old Feb 27, 2007 | 06:05 PM
Bayer-Z28's Avatar
Oversteer = loose = rear end wants to swing out easily, or feeling like it does.
Understeer = tight = Car does not want to turn, feels like it just wants to go straight.
Old Feb 27, 2007 | 06:29 PM
Capn Pete's Avatar
Funny because it's true!!
Although Bayer explained it a little closer to the "technical" descriptions .
Old Feb 28, 2007 | 06:15 PM
jaykar's Avatar
Wink a 3rd condition
And a nuetral car is where you pancake the whole side
of the car in the fence
Which could be good or could be bad
(Good); suspension setup up good, and you just stuffed it in to hard
(Bad); Broke loose easily, need to re evaluate setup at
both ends of the car
I always like having a slightly loose car to where you can
control the car using the gas. With a tight car and you lose
the front, you just induce more front end push when you have to
brake to slow it down.
HTH
Later
