No Brakes
Old Aug 15, 2004 | 08:14 PM
weinerschizel's Avatar
Question No Brakes
Ok. This is on an 94 Z28 w/ LT1 so hopefully I'm still in the right place.
I recently installed a new opti. Had the brakes off while I was doing this and painted the calipers. They were just unbolted not removed from the car.
After getting car running again, breaks wouldn't work. It feels like there is next to no brake pressure. When I push on the pedal it just goes to the floor. Of course car does not stop and dash lights up saying brakes.
I checked my fluid and it's perfect. What else is there to look at?
Thanks for the help!
Old Aug 15, 2004 | 08:29 PM
Black_Z28's Avatar
Re: No Brakes
Did you removed the brake hose from the caliper? If so, you need to bleed the brakes.
Old Aug 15, 2004 | 08:47 PM
Re: No Brakes
nope i didn't remove the hose.
Old Aug 15, 2004 | 09:01 PM
n2ceptor's Avatar
Re: No Brakes
Bleed the system.....Sounds like air in the system.... Was the calipers hanging or supported???? Could have damaged a brake line.....
Old Aug 15, 2004 | 09:14 PM
Black_Z28's Avatar
Re: No Brakes
Yeah, it seems as if air is in the lines. It will cause a very mushy/soft feel in the pedal. I'd bleed your whole system and see if that changes anything.
Old Aug 16, 2004 | 12:15 AM
magnumv8's Avatar
Re: No Brakes
I just put my car back together, and I have the same problem. I bled mine at the abs unit and all 4 wheels, but have a mushy pedal and no brakes. When we were bleeding we couldnt get much pedal pressure, but we did bleed air out then clean fluid so I thought they were fine. I am not leaking any fluid so I guess I will try beeding again.
Old Aug 16, 2004 | 10:23 AM
Re: No Brakes
Well they did get dropped. Stupid thing got out of my hand. However, after dropping (each one ug) I very closesly inspected the brake lines. They appeared to be good.
Is it possible just by dropping a line I could have introduced an air pocket? The system remained sealed, and the fluid levels are good.
Old Aug 16, 2004 | 01:21 PM
Mtrhds94Z's Avatar
Re: No Brakes
I doubt dropping one introduced air, however dropping one COULD kink the line[theres a line inside the rubber sheathing part and you won't see a kink]
Any time I have seen a 'kinked line' however the usual symptom is that the brakes apply OK but won't 'retract/release' properly[pressure remains in that caliper] heats the rotor, etc.. can be a tricky one to find too since you don't readily see it..
I really have no theory for your problem.. just removing and painting the calipers [with lines attached]shouldn't cause no brakes..
Old Aug 16, 2004 | 04:11 PM
Re: No Brakes
Are there any electronics associated with the brakes that would cause them to not function?
Old Aug 16, 2004 | 08:44 PM
Re: No Brakes
I bled the brakes. Still no dice.
It was my first time to bleed them though. I just had someone pump the brakes (farthest brake to closest to the master cylinder) and caught as much fluid as possible. All the while keeping the resivour full.
Still no luck.
Old Aug 16, 2004 | 09:08 PM
Black_Z28's Avatar
Re: No Brakes
Did you bleed the ABS system as well??
If you didn't you need to "home" it first. Turn the key to the on position for 10 seconds, and wait for the ABS light to turn off. Then turn the key to the off position for about 20 seconds. Then turn the key to the on position and wait for the ABS light to turn off again. Then go ahead and bleed the ABS. Bleed the one towards the back of the car first, then the one towards the front. Then bleed the calipers again, and do the ABS one last time.
Old Aug 16, 2004 | 11:08 PM
Re: No Brakes
Um bleed the ABS? Never had anybody explain that one to me. How does it work? There's fluid in there? I thought it was just sensors.
Old Aug 17, 2004 | 11:11 AM
Mtrhds94Z's Avatar
Re: No Brakes
I am wondering how air got in, if you didn't open the system?
Shouldn't need bleeding really..
Old Aug 18, 2004 | 10:38 AM
Re: No Brakes
Well I don't know it got in there. However, it must have gotten in. Found my problem. I bled the brakes again cause I did it wrong the first time. Now they work like a charm.
Thanks for the help!!!!!!!!
Old Aug 18, 2004 | 11:11 AM
slayer6x6's Avatar
Re: No Brakes
Those air powered bleeders are sweet.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
