Need torque specs
Need torque specs
I need torque specs for the following:
wheel hub that bolts to the spindel
upper and lower ball joints
lower control arm mounts to k memeber(I don't think there is a certain spec)
tire rod ends
I am runing a new bmr k member????
Thanks Mark
tire rod ends
Thanks Mark
Re: Need torque specs
Originally Posted by Z28barnett
Wheel Hub mounting bolts: 63 Lb*ft
Upper ball joint nut: 39 Lb*ft
Lower ball joint nut: 81 Lb*ft
Front LCA Bolt: 74 Lb*ft
Rear LCA Bolt: 85 Lb*ft
Tie rod ends: 35 Lb*ft
Z28
Z28
Thankyou so much.
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
