Need Suspension Help
Old Jun 3, 2004 | 09:31 PM
97SS4KS's Avatar
Gentleman,
I guess its time for a suspension upgrade. I have a 97SS. I have been seeing advertisements on polyurethane front end kits and I am interested but dont know much about them. Can you all please give me some feedback? Also, I am not sure what size sway bars that the SS's came with. As long as I am upgrading, might as well do these too. Thanks in advance.
Old Jun 6, 2004 | 04:13 AM
Compstall's Avatar
Changing the bushings out on the front is a real PITA. Next time, I ain't doin' it if the car don't need 'em.
I think I spent almost as much time doing the front bushings as I did the clutch swap..
Old Jun 6, 2004 | 12:47 PM
97SS4KS's Avatar
Thanks for the reply,
Actually you r right, I really dont need them yet.
Old Jun 9, 2004 | 11:18 PM
RedHottG2's Avatar
Everything you need is right here : http://www.bmrfabrication.com/faqs.htm and www.spohn.net
Just start out with weld in SFCs, Torque Arm, LCAs with brackets, and maybe a STB (althought I dont feel it's needed for straight line performance). Hope this helps
EDIT : I just saw your sig and you already have some of that stuff. But I guess you could still look at what tho's two sites have to offer anyway. Good luck!!
Old Jun 10, 2004 | 01:04 AM
ArizonaZ's Avatar
I mostly concentrated on the rear of mine, and I'm pretty happy with the results. I have polyurethane sway bar mounts, end links, and torque arm mount(very needed), plus the ones that came with the rear control arms and panhard. Pretty sure it could kick some *** on the skidpad now, even without the front control arm set.
Old Jun 10, 2004 | 08:08 PM
97SS4KS's Avatar
Thanks guys for the reply.
Old Jun 11, 2004 | 08:31 AM
mongse_1's Avatar
I'm guessing you're looking for more all-around performance, not just necessarily straight-line. The SS sway bars aren't too bad, so unless you feel you absolutely have to, I'd skip the sway bars. Are the endlinks stock? Might want to throw a set of Energy Suspension bushing on to replace the OEM ones. They'll make a little difference and it's not hard to do. Might want to look into an adjustable panhard rod as well to improve the handling a little. Not much more you can do w/o getting into the shocks/springs/sway bars.
BTW, any problems running a larger sway bar w/ the STS system?
Old Jun 11, 2004 | 09:31 PM
97SS4KS's Avatar
No, no problem at all. And thanks for your input. The car actually handles very well. I am leaning toward leaving things alone.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
