Need some help
Need some help
I am about to get either the eibach pro line or sport line lowering springs. Anybody have pics of either of these, also be able to give pros and cons on these(wheel rub).Do I really need to get relocation brackets or adj panarm bar?
adjustable panhard is needed, it puts the rear end back into the center.
relocations are nice, as it will bring the angle back taking away the ectra wheel hop you will get from lower.
you can run both without rubbing,
but the sport lines will make anything under your car hit anything taller then a couple inches
