Need help no making my car more confy and quiet.
Hey I moved back to my country about 4 years ago and I brought my camaro with me (94z28 m6) and the roads here suck so its very noise and probly loose from the use .
ive noticed that my center console where the radio goes is noise cuz of the cheap plastic. any recomendations on mods to make it more like a normal car meanning quiet ( i dont mind m exhaust) and not so jumpy. it has t tops so maybe sfcs woud help. Im thinking of maybe new shocks ,sfcs etc... thanks |
Originally Posted by cridom
(Post 5349791)
thanks , the only problem is that i live in chile so its hard to get em here.
Ill try to get some or otherwise i might have to wait for a friend to come to chile from the US. do u think shock and re tighten all screws and grease everything that needs grease would help a lot? BTW how much did you use of which products for your camaro? |
i dont think the shocks will do to much. the rattles are from everything being loose. i used 1 roll of raamaudio its 62.5 square ft. i did two layers on my driver door, 2 layers on the front floor and under both seats, one layer on the pass door, and almost 1 full layer on the truck. none under the back seat because i ran out.
alot of small things need to get done to make your car quiet. take your door panels off and adjust the the windows, the locks and handle. replace broke fittings and loose ones. i put rubber hose over the metal rods of the door handle and locks. the windows have hooks on the bottom mine where broke and it rattled alot. the trunk probably needs adjusted to tighten it with its closed. under the console the linkage on the shifter all rattled very bad while driving. i just used rubber tape to keep it tight and it took the noise away altogether (probably the biggest improvement other than the sound deadener). nothing was hard about all this just takes time and willingness to do it. |
thanks man
