Need Help with Air Bag Light & ABS INOP Light.GREMLINS
Old Apr 7, 2010 | 01:02 PM
PoorMansVette's Avatar
Hi i have a 94 Camaro z28 m6 wit the ABS inop light which comes on as soon as i start moving. I have cleaned the Ground Terminals near the battery, and have searched for as much info as possible with little luck on finding the right fix. If anyone has any insight,suggestions or can shed some light on what they did to fix similar issues i would really appreciate it. I love the forums. Without you I'd have to buy a Honda. Thanks!
Old Apr 7, 2010 | 02:47 PM
FastandBlue's Avatar
True words on the Honda! That's what I had right before my z28. Could it be a faulty sensor? Any codes?
Old Apr 11, 2010 | 02:55 AM
I'll have to run the diagnostics again.
Old Apr 11, 2010 | 07:19 AM
Guest47904's Avatar
Guest
Electrical problems....Ugh..
I decided to start with the easy one. If the ABS light is off but comes on when you move. This is referred to as a soft failure and is almost always the wheel sensors. If you could scan it you would see that. Most likely the rear sensor in the differential but not always. Depth, tightness and metal contamination all have an effect on the rear sensor.
Airbag is harder. My suggestion is check 2 of the 3 main fuses used for that system. They are: Fuse #1 15 amp, you already know Fuse #9 10 amp is good cause the airbag light is on. Last one is Fuse #16 3 amp.
Then if need be, check the grounds at the right hand shock tower and behind the left kick panel.
Unplug and reconnect C200. It's the huge 48 pin connector also behind the LH kick panel.
After that, we have to ram our heads together to figure it out if that doesn't help.
Old Apr 11, 2010 | 07:19 PM
speedy, thank you for the advice. I will look into that this week and let you know what i find out. Thanks again for the help, i do appreciate it.
Old Apr 17, 2010 | 11:58 PM
RE: speedy
speedy you da man! I checked/cleaned all the connections, and no more air bag light. As far as the ABS inop light codes, i had my mechanic scan for them and will update the codes tomorrow. The one that i know of for sure was the rear sensor as you mentioned was in an open loop/bad ground. The weird thing is that on the scanner all of the wheel sensors seem to be showing the the mph going forward, but the front right sensor does not register the mph when going in reverse. If there was a problem with the rear sensor functioning wouldn't it not show the MPH? any ideas? thanks
Old Apr 18, 2010 | 06:29 AM
Guest47904's Avatar
Guest
Scanner will show the one that does not work properly when the ABS light comes on.
Old Apr 19, 2010 | 02:08 AM
Wart Hog's Avatar
Abs inop
Check your 3rd tail light bulbs. I know it sounds crazy, the system sees the restance of the bulbs and when they come on it drops out the cruise. For some reason GM put the ABS system in line with this circut.
I had the same problem, Another member on this forum gave me the heads up. I changed a blown bulb and it cleared the code.
Hope this works.
Old Apr 20, 2010 | 04:36 AM
Guest47904's Avatar
Guest
and the ABS inop light which comes on as soon as i start moving.
His problem is a soft failure. The light only comes on when he starts to move. Not the bulb.
Old Apr 20, 2010 | 04:49 PM
The Code is 93
Old Apr 23, 2010 | 05:29 AM
Guest47904's Avatar
Guest
A 93 tells you that you had previously set a code (91 or 92) for a problem brake switch signal. Remember that big 48 pin connector I told you about earlier? Guess what goes through it? Power to the switch. Check the brake lights come which I believe they do. After the switch, it branches off on a yellow wire to the 12th pin of the EBCM. Check the connector at the EBCM for voltage when the pedal is depressed. The EBCM is above the left foot under the dash. Metal box, can't miss it.
rwferguson43026
Feb 6, 2015 10:06 AM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Jul 4, 2005 05:00 PM
