need brake help
Old May 26, 2004 | 07:59 PM
400hp ss's Avatar
need brake help
My abs inop,low trac,and emergency lights are on, the emr brake and low trac go off after driving but the abs inop stay on whats going on the brake pads still have a good life on them any help?
Old May 26, 2004 | 08:36 PM
95 Z/28 LT1's Avatar
Super Moderator
Check to see if your 3rd brake light is functioning. If it is burned out it can cause the brake light to come on.
Old May 26, 2004 | 08:52 PM
Bone Daddy's Avatar
Re: need brake help
Since the ABS inop light is staying on, and your getting the "casino" effect, thats usually a major failure in the system's mechanical side. Master cylinder, pump, or a slew of other bad things. Most of the time the light will flash for 3 seonds then stop if it's an electrical/sensor problem. You seem to be not-so experienced with the ABS system, take it to a qualified mechanic, and have the entire brake system checked.
Old May 29, 2004 | 11:39 PM
OBE1 95Z28's Avatar
A bad ground connection can also give you the dashboard "light show". The ground stud on your passanger side fender well (next to the red positive cap) is usually the culprit. Disconnect the negative terminal on your battery. Remove the nut and wires on the ground stud. Unscrew the ground stud and scrap/sand off the paint under the stud. Clean the bottom of the stud and reassemble. Cured the problem on my friend's 95 Z28.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
