need advice on used ls1 brakes
at the junkyard , there is a wrecked 99Z that i want the brakes off of do do ls1 conversion. they look to be in good condition except for the rust on the inside of the fins. he wants 200 for 4 calipers and rotors . is this a good deal? how about a price - the rotors? thanks
Re: need advice on used ls1 brakes
You need more than just the calipers and rotors, you also need the front spindle arms. If the car was hit in the front, then you have to be careful that these arms aren't bent.
thanks
I could be wrong, but don't LS1's have a different master cylinder, too? I know their front breaks are 2-piston calipers, whereas LT1 breaks are only 1-piston. It seems to me they must be running more lines, at least.
I'd say just upgrade the front brakes. The LT1 rears are singled pistons, but they're PBRs and are very good calipers. Most folks just do the front...I'm still in my "gathering" mode to do my LS1 swap.
Yes, you need more than the calipers and rotors. You'll need the front spindles and you can re-use the front hubs. I hear that you can re-use the existing LT1 front line and bend the bracket to make them reach, but I'm thinking if you're already in there, get yourself some LS1 stainless steels lines as well.
As for a new master cylinder, I haven't heard that. Even though the front is 2 pistons, there's still only one line to the calipers.
See what he quotes you for just the fronts...I wouldn't pay $200 for all 4. Else, check in EBay...there's always someone selling LS1 front brake kits. Else, do a search on the message board...I hear there's a salvage yard in Ohio or so that sells the full kit (spindles, calipers, rotors) for $135 shipped...something like that.
>>what are PBR's? also i know they are aluminum and the fronts are iron, are the LS1 fronts alum. or iron?
>> if he can cut me a deal on the hubs too should i just get them??
>> i am planning on getting s.s. lines without a doubt.
>> i havent heard that either and one line still makes sense
thanks for the help!
The LT1 master cylinder will work fine with the LS1 (or other aftermarket brakes). The LT1 piston size is enormous compared to the LS1, and I think the volume is actually greater on the LT1 than the LS1 for the front pistons. From my upgrade, here is what's needed:
front LS1 spindles
front LS1 calipers
front LS1 pads
front LS1 rotors
You can either reuse your stock LT1 lines by bending the tab down to a 90 degree angle or you can get longer lines. Either way will work fine.
front LS1 spindles
front LS1 calipers
front LS1 pads
front LS1 rotors
[QUOTE=LT4Firehawk]The LT1 master cylinder will work fine with the LS1 (or other aftermarket brakes). The LT1 piston size is enormous compared to the LS1, and I think the volume is actually greater on the LT1 than the LS1 for the front pistons. From my upgrade, here is what's needed:
front LS1 spindles
front LS1 calipers
front LS1 pads
front LS1 rotors
i have a buddy that said i can have his front rotors , so at the junkyard what would you guys say is a reasonable price for front calipers and spindles?
front LS1 spindles
front LS1 calipers
front LS1 pads
front LS1 rotors
carguyshu
Jan 22, 2017 11:19 AM
jj_burchiel
Mar 21, 2015 12:51 AM
