My Panhard rod fell out while driving!
So I'm driving in a school zone on Friday and I take a left turn. All of a sudden I hear something dragging under my car. So I pull over thinking that I'm dragging something that I ran over. I look under the car and my panhard rod is hanging down from the drivers side still attached to the passenger side! The bolt was completely gone. I put a new panhard rod from UMI about 2 years ago and I know that all the bolts were tight. Guess I should have bought the new bolts. At least the panhard rod is still good, only the bushing got a little scraped up. No one has the bolt, now I have to get the dealership to order one. Have you ever heard of this happening?
Re: My Panhard rod fell out while driving!
Originally Posted by RE AND CHERYL
You should be able to go to a local hardware store and get one. It's just a nut and bolt. Pull the other one to get the right size.
Re'
Re'
The pnahrd bar bolt is a tappered bolt, not something you will find at a hardware store and can only be purchased from GM. If you need to use a hardware store bolt a 1/2" will work but will be loose and may cause some noise.
Trevor98ramair
Jul 31, 2002 02:43 PM
