LT1 car rocking from side to side!
Old Jun 25, 2007 | 10:57 AM
DontMixWithRice's Avatar
i noticed that now, its getting much worse. on the highway, i can only get till 55 in 5th gear, because anything faster will get the car rocking from side to side. i got it up to 80 or 85 and upon deceleration, the car starting rocking again from side to side. i had to pop it into 4th (yes, at 85) and let the rpms slow down the car, and straighten it out.
has anyone ever seen this before?
Old Jun 25, 2007 | 11:42 AM
OldSStroker's Avatar
Check steering linkage for tight connections, front wheel bearings for slop, frontend alignment, especialy toein, and tire tread wear. For a quick check, grap the top of the front tires and pull/push them in and out. The shouldn't move hardly at all. Also grab front or rear of front tires and pull/push. I suspect loose steering or suspension parts. For gosh sakes do it before you drive again.
You might also check to see that power steering pump is firmly attached to the engine while you are checking tohe steering rack for tightness.
Old Jun 25, 2007 | 12:17 PM
turnin20s's Avatar
+1 Please do not drive until you check what was mentioned. It could be something simple, or could be everything. A friend on mine had a 3rd gen and he broke a tie rod end, but lucky for him there was an animal in the road and he was slowing down to let it get away and it broke when he was only doing ~15 mph.
But there can be a long list of parts that you may need....
Inner and outer tie rod ends
Upper and lower ball joints
Rack could be loose
Wheel bearings
Upper and lower control arm bushings
K member bolts loose???
Loose lug nuts???
Just check the simple things first and go from there
How many miles are on the car? It may be a good idea to start replacing parts anyway even if they aren't the problem.
Old Jun 25, 2007 | 12:34 PM
thank you guys...this has been printed, and will be checked out today.
luckily this bad boy is not a daily driver!
thanks again guys.
ro2207
Dec 4, 2014 06:18 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
