ls1-c5/zo6 brake upgrade
Old May 23, 2005 | 03:38 PM
drittz's Avatar
dont be too hard i went through all 8 pages of brake questions....
I have warped 3 sets of rotors on my 01 z28 and wanted to upgrade to c5/zo6 brakes in the front..... is it possible? if so what is involved?
thanks in advance
wv
Old May 23, 2005 | 07:57 PM
RE AND CHERYL's Avatar
Re: ls1-c5/zo6 brake upgrade
Several companies sell brackets to use C5 rotors with LS1 calipers (LS1 calipers are nearly identical to C5 calipers at a much lower price). I myself modified my stock LS1 caliper mount brackets to work with C5 rotors.
Old May 23, 2005 | 08:19 PM
Chewbacca's Avatar
...or you could just buy a pair of Brembo OEM replacement rotors for about $65 a piece.
Speaking from first hand experience, you won't warp those if you keep the impact wrench jockeys away from 'em.
Sam can hook you up.
Old May 24, 2005 | 07:49 AM
stereomandan's Avatar
Yeah, if you weren't aware of it, how you tighten down your lug nuts can warp a rotor. Make sure you are going in a star pattern and tightening them evenly.
Also, if you are hard on your brakes, give them a little chance to cool before parking the car.
You also could have eneven pad buildup on your rotors. Try going through a pad/rotor break in(bedding) procedure with your warped rotors. If you have uneven pad deposits on your rotors, this might remove the material and make the brakes smooth again.
If you are looking for info on the C5 brake upgrade(which I did, and you can see some pics in my webpage), I would recommend visiting www.frrax.com and searching the brake section.
Dan
Old May 24, 2005 | 11:11 PM
ponyackn's Avatar
what did you do to modify the ls1 mount brackets?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
