lowering springs
Old Apr 7, 2004 | 12:06 PM
re1080's Avatar
lowering springs
i've narrowed it down to either BMR or Hotchkis mainly because they only lower the car an inch and i want to get lt. I've also been looking at the KYB AGXs are they good shocks? any info would be great thanks in advance
Old Apr 7, 2004 | 05:37 PM
cndctrdj's Avatar
i have the eibach lowering springs and kyb gas adjust shocks... they are too soft. i like to hit corners hard and they just seem to give a little too much.do a search on shocks and see what the other options are unless you like a comfortable ride?!?
Old Apr 7, 2004 | 10:11 PM
Robs97Z28's Avatar
there is a better way to lower your car and spend less money and get better shocks.
You can run Konis in the front, shich allows you to lower the car about 3/4". In the rear you can run revalved Bilsteins (to save alittle money) or Konis. To lower the rear about 1/2" by removing a spring isolator and replace with a thinner peice of matieral. Like a peice of fuel line, cut out so it will warp around the spring.
You will save money have a better ride with much better shocks. The best part is, you will have the extra cash to buy a 35mm hollow front bar, so you can really rip around those corners.
Old Apr 8, 2004 | 06:18 PM
cndctrdj's Avatar
how much do the sway bars run
Old Apr 10, 2004 | 01:51 PM
1stls1's Avatar
Sway bars cost all diff $$,just depends on from who and what.Check out sup venders on that.If I lower my car 1"-1.5",would I need the relocating brackets and such?
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
