lowering and front end alignment ???
>It is necessary to get a front end alignment when you lower a car with springs right ?
I ordered the BMR springs and want to install them with the QA1 shocks .
Are the front springs the same replacement as the springs that are sold with the QA1 shocks ?
You should be able to ride around for a short time at least before you have to get the alignment done. You don't have to head immediately to the shop to have the work done.
I dropped mine quite a bit and it feels as though the alignment is still good, i.e it doesn't pull to the left or right, stays pretty much centered. I still plan on having things double checked next time I have it in the shop though.
